Dear Sir,
Can anyone help me in getting normalisation formula for Composition in ASPEN HYSYS/PLUS or any high fidelity simulator. hwo does it work generally ?
Please help me in this.
Chetan Chavan
Posted 28 June 2020 - 01:29 AM
Dear Sir,
Chetan Chavan
Posted 28 June 2020 - 09:26 AM
if you mean the normalization of feed fractions in many simulators these are normalized to 1.0 or 100 or ...(depending from selected range) with
z1(norm) = z1 / (z1 = z2 + z3 ... +zn)
but i suppose you question is different, can you provide additional details ?
Posted 29 June 2020 - 01:59 AM
Dear Sir,
Thanks a lot for your reply.
In any simulator, once we got to composition of any feed stream tab, we can enter component mol/vol/wt fractions and if sum of all these component values does not equal to 1, then we can normalise the composition by pressing normalise button . i want to know how this normalisation is done. i know that it will distribute rest of the percent to all other fractions with provision that higher the preent of current component , it will get higher weightage .let me know on this.
Posted 29 June 2020 - 03:58 AM
in most cases you specify weight fractions or molar fractions,
to convert from mole fraction to weight fractions calculate average molar weight (for that mixture), then wf(1) = mf(1) * mw(1) / mwm etc.
yes you can enter volume fractions but these are simply converted to molar (or weight) fractions via ideal gas law at normal or standard T,P conditions,
in general real volumes (calculated from a EOS or similar systems at specified operating consitions) are available (as enthalpies and other properties) as output (I attach a simple example showing the stream editor in Prode Properties, of course different simulators can show different information)
stream.jpg 96.19KB
2 downloads
Edited by PaoloPemi, 29 June 2020 - 04:06 AM.
Importing Component Stream Data From Hysys To Excel Using VbaStarted by Guest_TimL_* , 17 Aug 2018 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Aspen Plus Conceptual Mof Synthesis Model: Elecnrtl, Ionic Leachate, PStarted by Guest_Momo_212_* , 16 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
