Simulation Of Reboiled Absorper As A Distillation
Started by Abdulrazzaq S. Abdullah, Jul 05 2020 12:05 AM
Posted 05 July 2020 - 12:05 AM
I convert reboiled absorber to distillation , the top gas out is condensed and part of it return to the top as recycle.How I can make the recyle as specified variable in absorber?
Posted 19 July 2020 - 07:01 PM
Somehow I do not think you can. There are not enough degrees of freedom. Incidentally what software are you using. I would recommend "ChemSep". It is free for the lite version and just simulate the distillation. Perhaps the easiest set of specifications are the bottoms flow rate and the Reflux Ratio. Then on the second go have a look at the RR suggested in the results.
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
Static Simulation Of An Atmospheric CduStarted by Guest_tomr91_* , 10 Aug 2025 |
