For PEtrochemical Plant, what is the range for temp/pressures uptill which PEng Robinson fluid package is valid ? like upto how much pressures and temps ranges ?
Chetan Chavan
Posted 06 July 2020 - 10:56 AM
Chetan Chavan
Posted 06 July 2020 - 12:02 PM
there is not a specific limit, the alpha function in Peng Robinson standard (not the different, extended, derivations) can return decent values on gas phase for Tr > 20, for liquid phase it is not very accurate, many extensions (as volume translation etc.) are available, see The Properties of Gases and Liquids or similar books for a detailed discussion
Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
Chiller Package With Different FootprintsStarted by Guest_nabeelsp1036_* , 24 Oct 2025 |
Two-Phase Fluid Flow Through An OrificeStarted by Guest_frwvelandria_* , 13 Oct 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
