Hand Calculation For Condenser Duty For A Distillation Column
#1 timshelka
timshelka
  • 5 posts
Posted 13 July 2020 - 05:43 AM
I am in need of help. I need to do a hand calculation for a distillation column. i have done the material balance including the reflux rate and vapor rate and all the other stuff such as number of stages etc.
My overhead stream is at a dew point temperature of 60.4°C at a pressure of 11atm.
The overhead steam contains mostly DME which is 0.995wt%(dimethyl ether). I now want to calculate the enthalpy of the overhead stream before it enter the condenser. I know BP of DME is -24°C at atmospheric pressure. My initial assumption is that the enthalpy for that stream is evaluated using dme only as it contributes more than any of the other components.
I have tried using different methods but i am failing to calculate the enthalpy because i dont know how to calculated the enthaply of the dme at 11atm. Please help
  • 7,030 posts
Posted 13 July 2020 - 06:10 AM
If your condenser is a total condenser you need only the Delta H of condensation (vaporization) .
Consider the documents attached :
https://www.ncbi.nlm...les/PMC4294737/
https://webbook.nist...=C115106&Mask=7
Edited by breizh, 13 July 2020 - 06:11 AM.
#3 timshelka
timshelka
  • 5 posts
Posted 13 July 2020 - 06:30 AM
Thank for your response.
Looking at the article you provided, it gives the Hv as a function of a temperature. In my reporting will it be fair to assume that the calculated Hv at a temperature of 60.4degrees is the same for a wide range of pressure?
#4 breizh
  • 7,030 posts
Posted 13 July 2020 - 07:03 AM
To add to my first answer take a look at Clausius Clapeyron equation using your favorite search engine or textbook .
Same for Trouton's law .
Edited by breizh, 13 July 2020 - 08:05 AM.
#5 timshelka
timshelka
  • 5 posts
Posted 14 July 2020 - 12:38 AM
Thank you very much for your help
