Selecting Steam Trap For Turbine Condensate Removal
Started by memad, Jul 23 2020 05:49 PM
Posted 23 July 2020 - 05:49 PM
Hi, can anyone explain what the purpose of steam traps is on turbine where the exhaust steam is still superheated? would that be for start-up only? and if it is right how I can size the trap needed and select it from manufacturers
Posted 24 July 2020 - 01:49 AM
Hi
If the steam is still super heated, yes then it is for startup and shutdown.
Refer the following link for trap selection:
https://www.spiraxsa...reducing-valves
Since the steam is still super heated, I think Thermodynamic should be good, like we use for steam piping/network. The trap should be located at the lowest point.
There might be a philosophy in your company about the drain size based on volume, you can use the same size of TD trap as drain size.
Ethylene Plant - Is The Dilution Steam Generation System An "unfirStarted by Guest_Alfreedo_* , Yesterday, 02:31 PM |
Removal Of Mosh/moah ContaminationStarted by Guest_DistillationChris_* , 16 Jan 2026 |
