Chimney Tray Sizing For Vapor Disengagement
distillation chimney tray vapor disengagement vacuum residence time
#1 emma14778
emma14778
  • 10 posts
Posted 29 July 2020 - 10:36 PM
I am designing a vacuum distillation column with a chimney tray and a side product stream in a glycol/water vacuum distillation column. I would typically size the chimney tray to achieve a residence time of 3-4 minutes and sizing the risers to ensure reasonable pressure drop. The residence time of 3-4 minutes is chosen based on process control considerations.
The chimney tray is feeding a product pump and I am worried about carrying vapor into the pump. Are there any rules of thumb for ensure proper vapor disengagement on the chimney tray?
Let me know if more information is required.
Emma
#2 PingPong
PingPong
  • 1,474 posts
Posted 01 August 2020 - 09:23 AM
No.
Make a trap (step down) at the side of the chimney tray so that the top of the draw off nozzle is a half nozzle diameter below the floor of the chimney tray.
#3 breizh
  • 6,940 posts
Posted 02 August 2020 - 02:56 AM
Consider these resources :
https://www.slidesha...llation-columns
https://www.gtctech....-ptq-q2-gtc.pdf
Edited by breizh, 06 August 2020 - 01:14 AM.
#4 katmar
katmar
  • 699 posts
Posted 05 August 2020 - 09:09 AM
In downcomer design a residence time of 5 to 7 seconds is generally regarded as sufficient to ensure adequate vapor disengagement. In my opinion, if you have a residence time of 3-4 minutes and you install an internal sump as described by PingPong you will have no problems at all.
#5 emma14778
emma14778
  • 10 posts
Posted 11 January 2021 - 02:15 PM
Thanks for the feedback everyone. Went with the 3-4 minute residence time and internal sump. No issues on startup.
