I am an Aspen Plus beginner, and I followed the example provided by Aspen Plus to simulate step by step, but there was a problem.
In the process of simulating Moving Bed Coal Gasifier, the following warning appears:
->Processing input specifications ...
* WARNING IN PHYSICAL PROPERTY SYSTEM
PARAMETER PC/ELEMENT 1 (DATA SET 1)
UPPER BOUND VIOLATED FOR COMPONENT C
VALUE = 0.22300E+09, UPPER BOUND = 0.10000E+09
PARAMETER FREEZEPT/ELEMENT 1 (DATA SET 1)
VALUE = 4300.0 , UPPER BOUND = 4000.0
If you any tips or suggestions, you are welcomed.
Thanks in advance.
Edited by Jade331, 18 August 2020 - 10:17 PM.
