Dear all,
Can a malfunctioning check valve installed on a centrifugal compressor somehow restrict the flow and overload the compressor? if yes, how and in what way it could do that?
regards.
Posted 22 August 2020 - 07:00 PM
Dear all,
regards.
Posted 22 August 2020 - 07:45 PM
Only your data will tell.
Posted 22 August 2020 - 08:43 PM
Posted 24 August 2020 - 03:20 AM
Check valve is a mechanical device and can fail. One can rely on the check valve only if it is Class 1 i.e. periodically maintained.
Failure of check valve can lead to blocked outlet, the same as control valve failure or inadvertent manual valve closure.
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
