Methyl Chloride Abatement Technology
voc abatement
#1 TheChemEng
TheChemEng
  • 47 posts
Posted 26 August 2020 - 04:34 AM
Hi all,
We have a waste gas stream comprising of several VOCs that we would like to treat sufficiently enough to comply with the new mass threshold of 200g/h Total VOC limit in the near future.
We currently employ a cryogenic condensation system (-40oC) but would like to add a DMF purged scrubber (0oC) and then a water scrubber. This arrangement will remove all the VOCs down to a small level except methyl chloride!
I'm not keen on installing a thermal oxidizer due to: cost / availability issues / complexity / furans / environmental damage via CO2.
Is anyone aware of any novel or alternative abatement technology that is applicable to methyl chloride that doesn't involve a thermal oxidizer?
Andrew
  • 6,940 posts
Posted 26 August 2020 - 06:41 AM
https://www.messergr...as-purification
Consider the link above ,
May be more efficient than your current set up ?
#3 jcb994
jcb994
Posted 27 August 2020 - 02:42 PM
-40 C does not capture MeCl?  Perhaps look at increasing the surface area?  You can always do carbon filters but depending on mass flow could be changing them out pretty regularly.
#4 TheChemEng
TheChemEng
  • 47 posts
Posted 03 October 2020 - 02:00 PM
Thanks for the link and replies, much appreciated.
I'm thinking that my only alternative to treat methyl chlorides economically versus a thermal oxidiser is to install an abatement system (liquid/gas nitrogen cooling) targeted at the units responsible for emitting methyl chlorides.
