Hello All, I am Sravan. Can anyone help me with finding the properties of Nitrogen gas via., density, specific entropy and enthalphy, dynamic viscosity as a function of temperature and pressure. Can I calculate these values from any other available properties of Nitrogen, if yes what and where can I find them.
Thank you very much in advance
Properties Of Nitrogen As A Function Of Temp And Pressure
Started by Sravan123, Oct 31 2020 01:12 PM
nitrogen psychrometirc properties temperature pressure
Posted 31 October 2020 - 01:12 PM
Posted 31 October 2020 - 07:07 PM
Consider the resources underneath :
https://webbook.nist...hemistry/fluid/
https://www.cheric.o....php?cmpid=1930
You still have the possibility to use EOS , spreadsheet attached using Peng Robinson EOS .
Edited by breizh, 01 November 2020 - 12:08 AM.
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
