Restriction Orifice Design And Selection
ro sizing ro selection restriction orifice manual blowdown
#1 nsr.kn85@gmail.com
nsr.kn85@gmail.com
Posted 03 November 2020 - 06:27 PM
Hello there,
I need to design a restriction orifice on a manual vent to atmosphere -
Vent Line Size DN50
Main Line Size DN300
Fluid - Natural Gas - dehydrated
P - Inlet = 15000 KPag
Temperature = 24 DegC
I have calculated the orifice diameter for critical flow condition, it came out to be a 7 mm hole. however, I don't know how to select the rest of the sizing. For example the material of orifice or is there any standard size which i can select and order??
thanks and regards,
  • 7,037 posts
Posted 03 November 2020 - 11:47 PM
What about the flowrate and gas composition and /or other fluid properties ?
Regarding material let you try your favorite search engine , it could be bronze , SS 316 ,SS 304 .
note : You have a look to GPSA for additional information
#3 fallah
  • 5,026 posts
Posted 04 November 2020 - 12:15 AM   Best Answer
Vent Line Size DN50
You have set having the required venting flow rate as critical flow for a delta P equal to 15000 KPag around the Restriction Orifice and then obtained the required hole diameter in the orifice plate; right?
For material and standard size also confirming the calculation you have performed; it's better leaving them to a reputable vendor by providing all data in a data sheet...
#4 Bobby Strain
Posted 04 November 2020 - 09:55 AM
You also need noise suppression. So, do as Fallah suggests.
