Restriction Orifice In Biomass Slurry Application
#1 Biomass Process
Biomass Process
  • 15 posts
Posted 28 April 2026 - 10:23 PM
Can we use the Restriction Orifice in Slurry Application . Checked on net and books -it is not recommeneded as fibrous slurry having un-even size biomass particles can cause frequent plugging of RO and also it is abrasive -having silica. Any toughts on this .
  • 7,064 posts
Posted 29 April 2026 - 01:27 AM
What is the application and the reason to install an orifice? a sketch will help
Better description better answer
#3 latexman
  • 1,934 posts
Posted 29 April 2026 - 05:49 AM
In slurry, RO is a one hole strainer.  Best to avoid.
#4 breizh
  • 7,064 posts
Posted 04 May 2026 - 06:28 AM
Multi holes orifice could be an option to mitigate the risk of plugging.
Google AI:
Multi-hole orifice (MHO) plates are used in biomass slurry processing to enhance hydrodynamic cavitation, a process that creates pressure changes, forming and collapsing vapor microcavities that break down the lignin-carbohydrate matrix in biomass. These multi-hole designs are preferred over single-hole orifices for improving pretreatment efficiency because they offer a higher shear area and higher cavitation intensities. [1, 2, 3, 4]
Hydrodynamic cavitation for lignocellulosic biomass pretreatment: a review of recent developments and future perspectives - PMC
#5 Falah
Falah
  • 34 posts
Posted 05 May 2026 - 08:52 AM
Spring-closure valves are often used instead of a restriction orifice in services which tend to clog openings.
If the valve begins to clog, it can be opened fully and then returned to a stop for its partially open position.
