Posted 04 November 2020 - 05:32 AM
Posted 04 November 2020 - 01:14 PM
superficial gas velocity of the gas (gas flow rate / cross-sectional area)
Or in other words: superficial gas velocity is the gas velocity if the column would be empty.
bubble rise velocity
That is the velocity with which gas bubbles rise upward through a liquid. Apart from gas and liquid properties that also depends on the bubble size: smaller bubbles rise slower than big bubbles.
I don't understand what value to insert in the correlations for the calculation of the mass transfer coefficients.
Normally some text explains which variables to insert in a correlation, and in which units of measurement.
So read all text surrounding the correlation carefully.
are there any correlations between these velocities?
No.
Edited by PingPong, 04 November 2020 - 01:16 PM.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
Packaging And Gas Velocity In Packed ColumnStarted by Guest_ChemEng_CristianoB_* , 25 Jun 2025 |
