Tank Sizing Calculation
tank sizing
#1 274@P6
274@P6
  • 43 posts
Posted 05 November 2020 - 03:29 AM
Hi all,
Is there any calculation available to find the tank volume?
Data i know, Tank inlet and outlet flow rate 80m3/hr and 30m3/hr respectively. Water treatment Plant total capacity is 600m3/day. how to find the tank size?
#2 fallah
  • 5,026 posts
Posted 05 November 2020 - 03:44 AM
Please also specify the inlet/outlet flow rate on daily basis...
#3 274@P6
274@P6
  • 43 posts
Posted 05 November 2020 - 04:11 AM
Have to supply 550m3/day of water (Outlet flow rate) constantly from the treatment plant.
#4 breizh
  • 6,939 posts
Posted 05 November 2020 - 04:48 AM
This link to support your work :
https://www.webpages... Guidelines.pdf
Hope this is helping you
#5 fallah
  • 5,026 posts
Posted 05 November 2020 - 06:40 AM
Based on 80 m3/hr as input rate you should have around 7 hr/day production (550/80) while there should be a consumption rate equal to around 18 hr/day (550/30); hence in worst case supposing within 7 hr production per day there would be no consumption (the consumption as out flow happens totally in remain hrs of a day i.e. around 16-17 hrs) the working volume of the tank should be 550 m3...
