Ratio Controller
ratio control
7 replies to this topic
#1 274@P6
274@P6
  • 43 posts
Posted 05 January 2021 - 01:21 AM
Hi to all,
Could anyone explain how the ratio controller works?
I need to prepare the solution (Water+Polymer) for a constant viscosity. How can i fix the ratio control to maintain constant viscosity?
  • 7,030 posts
Posted 05 January 2021 - 02:00 AM
I don't think this is possible ! You need a very good mixing device and a inline viscometer at the outlet of the mixer .
What is the form for the polymer : liquid , solid (pellets , flakes, powder ) ?
Is it a continuous or batch process ?
You should consider to keep one stream constant (water) and add more less polymer .
My view
#3 fallah
  • 5,026 posts
Posted 05 January 2021 - 04:04 AM
Supposing the polymer in liquid state, at first you should experimentally find the ratios of water/polymer to meet the specified viscosity at fixed temperatures; then using flow control valves at incoming water/polymer lines to mixing vessel triggered by a ratio controller has been set at found temperature corresponding ratio you will have a solution with mentioned specified viscosity.
#4 latexman
  • 1,922 posts
Posted 05 January 2021 - 07:41 AM
A more detailed process description might help.
#5 274@P6
274@P6
  • 43 posts
Posted 18 January 2021 - 12:33 AM
Hi to all,
Kindly find the document attached. will it works?
Edited by 274@P6, 18 January 2021 - 12:35 AM.
#6 latexman
  • 1,922 posts
Posted 18 January 2021 - 08:05 PM
Has it been successful before? If not, I’d do a test at the static mixer vendor.
#7 Bobby Strain
Posted 18 January 2021 - 11:39 PM
Looks strange to me. You don't provide enough information to even guess.
#8 breizh
  • 7,030 posts
Posted 19 January 2021 - 01:22 AM
Did you check with the polymer's suppliers ? They know their products and can give you some advices .They may also provide equipment for the dosage in line as part of their contract to sell chemicals .
This is based on my experience with water treatment companies .
