Hello fellow HYSYS users,
I am working on a compression package using HYSYS Dynamic. There are a few kettle-type heat exchangers in between compressor stages in which wet CO2 enters the tube and cools down to 125 C. On the shell side (liquid) water enters at 104 C and exits at 115 C steam (vapor). There are two concerns:
1) The UA value should be specified in dynamics and it should change over time during transient scenarios (shutdown and start-up). UA is not a constant.
2) Water level in the shell also needs to be controlled in order to maintain the outlet tube stream at 125 C.
How can points 1 and 2 be done in HYSYS S&T heat exchanger? I would appreciate your response in detail with a HYSYS example file (if possible).
Mahsa
