Hello Dear Sir/ Madam,
I want to drain a propane vessel by transferring it to another vessel via compressors and condensers . It consists to add hot gaseous propane in order to accelerate the vaporization rate.
Knowing the mass m= 374 T, the hot propane has flow q= 401 Nm3/h and the propane density at -42°C Rho= 581 kg/m3, how can I calculate the duration to vaporize all the propane ?
Is it enough to answer the question ?
Do you need further information ?
Any suggestions ?
Thanks you for your help
