Hi folks
I need to find some physical properties for a gas mixture - viscosity, thermal conductivity, and heat capacity (Cp). The gas is at 210 Celsius and 30 bar, and consists of hydrogen, nitrogen, carbon dioxide, and water vapor (the mole fractions are known). The mixture behaves ideally (Z overall approx. = 1.0), therefore I guess i would find the physical properties at the T, and multiply the property by the mole fraction for each substance in the mixture (but i'm not sure this is right). I dont need a 100% accurate value for this as other factorsare more significant.
Any help would be appreciated.
Thanks!
Physical Properties
Started by , Oct 24 2006 01:18 PM
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
Question Distillation Column Transport PropertiesStarted by Guest_panagiotis_* , 05 Apr 2023 |
Manual Creating New Component And Setting Properties In HysysStarted by Guest_Platonicus_* , 15 Mar 2023 |
Question Properties In Aspen PlusStarted by Guest_panagiotis_* , 23 Mar 2023 |
Liquid Mixtures Properties EvaluationStarted by Guest_Jorge Kley_* , 21 Dec 2022 |
