We have chlorination process plant and we have to transport it from tonner to plant. As of process side they provided height of 10 m to dry chlorine piping. What is the reason of that ?? one of it's reason is to avoid back pressure may be..any other idea that why it has height of 10 m.
Chlorine Gas Piping
Started by Jaldhipatel, Feb 17 2021 11:17 AM
Posted 17 February 2021 - 11:17 AM
Posted 17 February 2021 - 02:38 PM
A sketch of the source tonner, the piping in question and some downstream details will help in answering your question. There can be many reasons for any particular design.
Posted 04 April 2021 - 12:44 AM
Normally from chlorine tonner process plant height is about 25 m..but chlorine line has excess 10 m head near process area and then go to consumption source..we have 2 different process areas and for both facilities same 10 m excess height given into line..pls suggest why it is there..i have may be two ideas in mind 1) to avoid back pressure 2) to get moisture free chlorine at consumption side
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
Pressure Drop In PipingStarted by Guest_Jaldhipatel_* , 05 Jun 2022 |
Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
What Are The Differences Between Ph,orp & Chlorine Dioxide AnalyseStarted by Guest_Radha Krishnan Siva Kumar_* , 01 Apr 2024 |
