Why would a selectivity of methacrolein increases when inlet pressure increases through a packed bed reactor?
Selectivity Vs Pressure
Started by Rachel Tee, Mar 02 2021 10:32 AM
No replies to this topic
Posted 02 March 2021 - 10:32 AM
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
How To Determine The Pressure At A Mixing Node For Two Streams With DiStarted by Guest_samin_chemeng_* , 02 Oct 2025 |
