Fluid Package For Nitrogen Refrigeration Cycle
7 replies to this topic
#1 JaiEdi
JaiEdi
  • 23 posts
Posted 05 March 2021 - 05:07 AM
I have designed a simple single stage nitrogen vapour compression refrigeration cycle. Is Peng Robinson a suitable fluid package to work with in UniSim?
Similarly is Peng robinson sufficient for a propylene, ethylene, methane refrigeration cascade?
How could I justify this if it is the case?
  • 6,941 posts
Posted 05 March 2021 - 06:33 AM
Take a look at this thesis , you may find pointers :
http://ethesis.nitrk...lication_detail
Google or your favorite search engine should be your ultimate resource.
Edited by breizh, 05 March 2021 - 06:38 AM.
#3 latexman
  • 1,894 posts
Posted 05 March 2021 - 07:42 AM
I use Aspen Plus, not UniSim.  Aspen Plus has a Property Method Selection Assistant, or "Methods Assistant" for short.  Does UniSim have similar for you to use?
If you had given all components and the range of T and P, I could have relayed what Aspen "Methods Assistant" said.
Edited by latexman, 05 March 2021 - 07:46 AM.
#4 JaiEdi
JaiEdi
  • 23 posts
Posted 05 March 2021 - 08:23 AM
That could be helpful so do you need the composition and range of T and P across the cycle?
#5 ChEf
ChEf
  • 21 posts
Posted 06 March 2021 - 05:20 AM
PR or SRK with LK for ethalpy should be fine.
#6 breizh
  • 6,941 posts
Posted 06 March 2021 - 05:33 AM
https://sutherland.c...tySelection.pdf
hi,
Consider the link above which confirms the package used in the thesis I forwarded to you .
Read Bob Seader's recommendation for cryogenic : PR and BWRS
Edited by breizh, 06 March 2021 - 05:50 AM.
#7 latexman
  • 1,894 posts
Posted 06 March 2021 - 07:14 AM
Let's make it easy.  List the components, and the lowest and highest T and P in your simulation.
#8 Pilesar
  • 1,637 posts
Posted 06 March 2021 - 09:11 AM
You want to use an Equation of State (EOS) for systems of the components you listed. An EOS is designed to calculate the effective partial pressure (fugacity) of the components as they somewhat deviate from acting as an ideal gas. Peng Robinson is a good choice as would be SRK. An EOS has accuracy problems when used to calculate liquid density. Consider using Rackett or Costald for better liquid density calculations. It should be easy enough to try other thermo methods after your model is complete to see how much accuracy risk you have in method selection.
