Hello Everyone,
In the aerospace industry, we tend to use terms low pressure, medium pressure, high pressure, and ultra-high pressure. I haven't come across any Codes (ASME, NB-23, API, CGA, etc)that explicitly state the limit of all pressure category.
The few that I was able to find, the limits are not consistent. For example, API-570 states high pressure as being greater than 150 psig, while ASME Section VIII, Div 2, implies very high pressure is greater than 10,000 psi.
is there a consensus on what limits are for each category?
S Le
Pressure Ragnes
Started by skle1967, Mar 23 2021 09:23 PM
Posted 23 March 2021 - 09:23 PM
Posted 24 March 2021 - 09:09 AM
There is no single set of universally recognized definitions.
The above sentence applies to any subject you select.
Posted 25 March 2021 - 12:21 PM
Thank you Pilesar.
PressureStarted by Guest_guoyinyanliner_* , 16 Nov 2026 |
Shell And Tube Pressure DropStarted by Guest_UofUChemE_* , 08 Jun 2018 |
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
