Light Naphtha Rvp
Posted 12 April 2021 - 12:48 AM
If more LPG in light naphtha so RVP will increase or decreases?
What is the the specifications for Light Naphtha RVP?
Posted 12 April 2021 - 07:13 AM
I think of RVP as indirectly measuring the percentage of butane. The results are pretty close for RVPs near 5 psi as usual for gasoline. Before RVP was a spec, butane in gasoline improved the performance of some lab tests for quality and was cheap for the refiners to include in the gasoline blend. Precise specs are negotiated between buyer and seller.
Posted 14 April 2021 - 01:58 AM
RVP is important mostly for storage reasons. More LPG gives higher vapour pressure and usually there is a limit on RVP for storage of naphtha in a tank. Butane has good octane and is advantageous to blend it into gasoline but only up to the storage limit or product specification for winter or summer gasoline.
Edited by SilverShaded, 14 April 2021 - 01:58 AM.
Naphtha StabilizerStarted by Guest_Ashokk_* , 24 Feb 2026 |
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
Naphtha PlatformerStarted by Guest_EngrHamza_* , 13 Jul 2023 |
Naphtha Stabilizer Pressure VariationStarted by Guest_mb23_* , 21 Jan 2023 |
Diesel And Naphtha Properties In HysysStarted by Guest_piyush123cheme_* , 29 Jun 2022 |
