Distillation Simulink
#simulink #distillation #processcontrol #pid
#1 Dcoz
Dcoz
Posted 26 April 2021 - 10:13 AM
Hello Dear Chemical Engineering community,
We are currently designing the simulink control for a distillation column, and attached below is what we have done so far.
We implemented feedback control. The problems is that we generated 4 PID controllers (two for the reflux and two for the reboiler) yet are required to only use 2 PIDs, so my question is how do we 'fuse' two PID controllers into one.
Any other comments or suggestions are highly appreciated.
Thank you
  • 1,635 posts
Posted 26 April 2021 - 08:51 PM
I am not expert at what you are doing (and am not sure I even understand what you are doing), but consider using a weighted sum of the changes calculated by both controllers.
#3 breizh
  • 6,932 posts
Posted 26 April 2021 - 09:45 PM
Not sure I understand your query . I added documents about Distillation towers and control . You may submit a simple PFD/PID for us to visualize your problem with sensors ,controllers and links between them .
My view
#4 horatorres
horatorres
  • 88 posts
Posted 27 April 2021 - 08:31 AM
  Dcoz
It is not possible to understand what are you doing without a P&ID   or the control loop drawing
horacio
