4-20 Ma Analogue Signal Conversion
analogue signal control current convert
#1 VLCENG
VLCENG
  • 8 posts
Posted 07 May 2021 - 06:46 AM
Hi, I have certain control setup:
Attached File  Control diagram.png   223.85KB   0 downloads
For that, I have data recorded for every I/O block, and I am asked to determine the function used by the AIN block to convert from an analogue 4-20 mA signal to a flow value in the range of 0/32 L/m. The plotted data looks like this:
Attached File  f_vs_I.png   65.3KB   0 downloads
How would you obtain that function?
Thanks for your time
Edited by VLCENG, 07 May 2021 - 06:49 AM.
#2 latexman
  • 1,935 posts
Posted 07 May 2021 - 09:20 AM
Excel graph can be used to get an equation to the function of several types.  Then, look at the correlation coefficient to select the best one.
#3 breizh
  • 7,065 posts
Posted 07 May 2021 - 11:25 PM
Yes Excel will do the job for you!
You already have the table and the graph ,  click on the graph you will find trend line with different models to select .
based on your data (4) : an estimate : Y (flow) , X (ma)
y=-0.2727*X^2+10.976*X-81.7
R^2= .9827
Edited by breizh, 09 May 2021 - 02:20 AM.
