Pressure Drop For Vertical Piping
pressure drop vertical piping height friction pressure gas
#1 zamakaze
zamakaze
  • 13 posts
Posted 01 June 2021 - 02:59 PM
hlo,
im trying to calculate the pr. drop in vertical piping for gas.
i have a vertical section where gas goes down in elevation 5 ft
the pressure at starting point is 85 psig
since there is fall of 5 ft i assume pr. gain can be calculate as = rho x g x h2-h1 where h2 is 5ft , h1 is 0 ft
for frictional drop can we just use the darcy eqn for vertical or there are some other considerations??
attachd sktch
  • Attached File  2311.jpg   27.68KB   0 downloads
#2 latexman
  • 1,899 posts
Posted 01 June 2021 - 03:30 PM
That looks right.  It's the Bernoulli equation with friction included.   Don't forget the fittings (2 elbows).
#3 breizh
  • 6,970 posts
Posted 01 June 2021 - 07:05 PM
hi,
The head loss due to the vertical part (altimetry) is very minimum ,negligable .  Bernoulli equation to apply.
Don't forget the elbows in your calculation .
#4 fallah
  • 5,026 posts
Posted 01 June 2021 - 10:41 PM
attachd sktch
For gaseous fluid there is no significant difference in pressure drop calculation for vertical and horizontal lines...
