Joule Thomson Coefficient For Natural Gas Mixture
#1 phani4cts
phani4cts
  • 9 posts
Posted 25 June 2021 - 10:10 AM
Hi everyone,
I want to calculate the Joule Thomson coefficient for a natural gas mixture manually. Can someone guide me the procedure for it? Please post links of some useful references in this regard.
Thanks in Advance
#2 MrShorty
MrShorty
  • 517 posts
Posted 25 June 2021 - 12:13 PM
Here's a youtube video deriving an expression for the JT coefficient.  From there, you would need an expression or table for Cp and an EOS or tabulated PVT data to get dV/dT.
That's a quick overview, which part of the calculation do you need help with?
Edited by latexman, 25 June 2021 - 12:24 PM.
#3 breizh
  • 6,804 posts
Posted 25 June 2021 - 11:07 PM   Best Answer
You may use a document I prepared a few months ago , 2 EOS  PR and SRK . You will have to enter in data bank sheet  the pseudo component based on your NG analysis .
You will need to apply Kay's rule ( google if necessary) to calculate the parameters to enter in the data bank sheet , under pseudo component .
note : Under Reference sheet you will find a set of equations and the method used to resolve them .
https://core.ac.uk/d...f/195693785.pdf
Hope this is helping you
I encourage you to do the math .
