Dear All;
Posted 09 July 2021 - 07:33 AM
Dear All;
Posted 12 July 2021 - 11:08 PM
Did you try your favorite search engine as I did ? keys words Prilling tower design
https://qdoc.tips/ur...n-pdf-free.html
notes :
you may need to contact companies mentioned in the link to support your work. Check also for GEA Niro.
you may find pointers in Perry's Chemical engineering handbook
Posted 13 July 2021 - 01:50 AM
Thank you for your respond Sir, I searched every ''prill tower design'' page in everybodys favorite search engine. Result were not satisfactory. I need more spesific details about designing parameters for prilling tower. The reason I wrote here was to exchange ideas with someone who had worked on the prilling tower before.
I'm going to check perry's hand book and ı will try to contact with companies. appreciated for your help.
Posted 13 July 2021 - 06:42 AM
You seem to be looking for a step-by-step recipe book for prilling tower design. I would be surprised if you found that. This assignment is pretty good for a student since engineering is not copy and paste. Determine the parameters of the process -- what is the feedstock? What is the desired product? Calculate the heat and material balance using first principles thermodynamics. Fluid flow and heat transfer will be important. The final design is up to the designer! Part of the fun of chemical engineering is the expression of art within the boundaries of science and economics and safety. As far as I know, there is no 'standard prilling tower' that you would be expected to discover in your research.
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
