How Can I Calculate The Volume Of Nitrogen Required?
#1 Engrabiolabusari
Engrabiolabusari
Posted 13 July 2021 - 08:04 AM
Hello professionals in the house. How can I calculate the quantity(volume) of Nitrogen gas required to leak test a 2"line of 24m length to a pressure of 147.5barg?
#2 latexman
  • 1,899 posts
Posted 13 July 2021 - 11:34 AM
That's over 4 times nitrogen's critical pressure of 32.9 barg!  It would be much safer, easier, and cheaper to just use water in a hydrotest.  Is there a reason water cannot be used?
#3 Bobby Strain
Posted 13 July 2021 - 11:51 AM
No one in their right mind would use gas to pressure test! It's quite dangerous.
#4 Pilesar
  • 1,652 posts
Posted 13 July 2021 - 12:02 PM
Leak tests are generally done at much lower pressures after maintenance and during recommissioning. Even though your line is rated at such high pressures, all that may be needed for a leak test is to pressure the line to perhaps 5 barg and block the line in to check whether the pressure drops over time.
#5 breizh
  • 6,971 posts
Posted 13 July 2021 - 06:38 PM
Safety first , forget about using high pressure gas for leak test ! this is too dangerous .
If possible use water and handpump to perform the task .
The use of gas can lead to fatality , I'm aware of one case .
