Hydrogen Power Plant
biogashydrogen oil combined heat power
#1 DavidFei
DavidFei
Posted 22 July 2021 - 07:29 PM
I'm having hard time in choosing a product that can sustain in a long run and its safe in environment, is CHP a good choice?
  • 7,058 posts
Posted 22 July 2021 - 08:54 PM
let you use google or other favorite engine : hydrogen power plant   (key words ) , a lot of stuff available from big companies like Siemens ,GE ..
https://www.siemens-...wer-plants.html
https://www.ge.com/c... Generation.pdf
https://www.energyli...-ebook-2020.pdf
By the way you should try to contact them and ask for reference(s) in your region
You may find pointers in the links attached :
https://www.epa.gov/chp/what-chp#two
https://netl.doe.gov...rbines/handbook
my 2 cents
#3 jackyclemente
jackyclemente
Posted 25 July 2021 - 07:08 PM
By generating heat and power simultaneously, Combined Heat and Power (CHP) can reduce carbon emissions by up to 30% compared to the separate means of conventional generation via a boiler and power station. CHP is highly efficient, making use of the heat which would otherwise be wasted when generating electrical or mechanical power. This is why its so important to choose a reliable source of electricity for your home.
