I have to calculate the order of reaction and reaction kinetics for a reaction which needs to be run in semi batch mode due to high exothermicity. How can I possible run an experiment and when the samples should be collected in order to plot C vs.t graph. The conversion is very fast so how do I know the concentration of unreacted is from the initial time t=0 or from the addition due to semibatch mode?
Calculate Rate Of Reaction For Highly Exothermic Semi Batch Reaction
Started by nkchem88, Aug 05 2021 06:31 AM
Posted 05 August 2021 - 06:31 AM
Posted 05 August 2021 - 06:51 AM
Several companies specialize in chemical reaction kinetic studies. To me, Fauske seems to be more open than most, so I recommend you learn what you can here:
https://www.fauske.c...eaction-hazards
Their site is full of good technical articles. Just look around it.
To get the data you are looking for, you have to design a batch experiment, not semi-batch. You have to eliminate the exact factor you asked about. You are trying to get data, not make product.
Can you share the chemical(s) and process you are studying? Someone may be familiar with it.
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Teg Dehydration Stripping Gas Flow RateStarted by Guest_SidRah_* , 20 Aug 2025 |
Steam Flow And Heating Time In Batch ReactorStarted by Guest_seagal6_* , 16 Jul 2025 |
Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
