1-Hexene Extraction Of Waste Output From The 1-Buten Unit
#1 Roozbeh.gh90
Roozbeh.gh90
Posted 02 September 2021 - 03:43 AM
Hello to all dear engineers, I have done a simulation with Hayes software there is :
Extraction of 1-Hexane from waste output ‌from unit
1-Butane Due to the near boiling temperature of feed component I used two distillation towers, but the number of trays became very large approximately 130-180. And
‌ I think condesnsor and reboiler duty is not normal and common ,also reflux retio and boiled up ratio for purifying productis very high about 22 for reflux and 1 for boiled up
( actually i thing they haven't correct scale)
Thank you for seeing my file and sharing your comments with me.
https://www.uplooder...ROJECT.hsc.html
Best regard
  • 6,919 posts
Posted 02 September 2021 - 04:43 AM
To help you we need to be able to open your file . Can you submit it on another format ,let say pdf ?
Do you use the right thermodynamic package? Do you have publication to support your process ? Are you sure about the operation condition  ?
Did you try with other commercial software ?
Note : You can download a free software from internet named ChemSep to perform your simulations .
Good luck anyway .
My 2 cents
