Pseudoproducts In Column Section Pro-Ii
pseudoproducts pro2 pro-ii column simulation
#1 smg@2021
smg@2021
  • 8 posts
Posted 10 September 2021 - 10:19 AM
I am working in Petroleum Refinery in Operations since last 6 years and I'm planning to learn simulation in Pro-II.
I am unable to find the reflux flowrate when simulating a diesel stripper. I have not set reflux ratio as one of the performance spec in the column.
How can I use the pseudoproducts in feed and product sections in Pro-II to determine the reflux rate?
  • 1,635 posts
Posted 10 September 2021 - 04:27 PM
Assuming your condenser is stage 1, you will want to define a pseudo stream for the net liquid from stage 1. In keywords, this is a TFLOW statement. In the GUI, you will connect an external stream to the column and define it inside the column block. Go to Column - Feeds and Products. Select the Pseudoproducts button to define the stream.
#3 smg@2021
smg@2021
  • 8 posts
Posted 12 September 2021 - 09:39 AM
For the reflux rate, I selected net tray flow.
Thanks a lot for the help!
