Air Cooled Heat Exchanger
#1 memad
memad
  • 10 posts
Posted 13 September 2021 - 04:33 PM
I have an i quiry about tube bundle maintenance
When an air cooled hea exchanger has a failed tube and going to plug it
Why it is necessaey to cut the tube from one side of the tubesheet after plugging it?
#2 niraj_kuwait
niraj_kuwait
Posted 22 September 2021 - 02:35 AM
Dont understand your question You mean to say you have cut the tube after plugging !?how it is possible !how could you reach face of Tube sheet?
#3 memad
memad
  • 10 posts
Posted 27 September 2021 - 01:41 PM
I can cut the tube from header backward after 10 cm from tube sheet to be able to separarte the tube from tube bundle
#4 Napo
Napo
  • 350 posts
Posted 24 November 2021 - 05:22 PM
Memad,
Maybe you can cut the tube in the bundle if you can acess to him, i.e upper row or bottom row. If the tube damages is in the bundle middle it´s not possible.
Maybe but if you cut the tube is for not permit the corrosion increase maybe of for to check what if the cause or origen the problem (corrosion, material failure, etc.).
Napo.
#5 Pilesar
  • 1,637 posts
Posted 24 November 2021 - 10:16 PM
Tubes can be cut or punctured from the inside wall to the outside wall with a special tool inserted into the tube end. Tubes are modified before plugging so that liquids cannot collect inside which might possibly lead to overpressure.
