Shell And Tube Heat Exchanger In Htri
he design and rating
#1 Sanjayr126
Sanjayr126
Posted 28 September 2021 - 10:28 AM
1. What should be the L/D ratio assumption in Heat Exchanger Design/Rating in HTRI for below systems ?
     a. Liquid-Liquid
     b. Gas-Liquid
     c. Gas-Gas
2. How to reduce the overdesign in HTRI?
  • 1,656 posts
Posted 28 September 2021 - 06:56 PM
There is no standard L/D ratio assumption in Heat Exchanger Design/Rating in HTRI. Tubes come in standard sizes, so choose one that seems reasonable and then optimize the design. Reducing surface area is one way to reduce heat exchanger overdesign.
#3 breizh
  • 6,975 posts
Posted 29 September 2021 - 12:35 AM
Consider these documents support your work .
To me nothing is related to software , only good engineering practices .
#4 lnbsak
lnbsak
  • 53 posts
Posted 08 October 2021 - 03:01 PM
I you have access to Aspen EDR. It can provide you an estimate of optimized STHE based on a few factors. But you can surly design based on Engineering judgment, vendor communications etc.
#5 Prim
Prim
  • 3 posts
Posted 05 November 2025 - 05:54 AM
In thermal design, the L/D ratio (Tube Length ÷ Shell ID) isn’t just a number—it’s the sweet spot between performance, cost, and practicality.
???? Too Low (L/D < 3): Oversized shell, poor heat transfer efficiency, higher material cost.
???? Too High (L/D > 12–15): Vibration risks, high pressure drop, fabrication & transport difficulties.
???? Optimum (L/D ~ 6–10): Balanced heat transfer, manageable pressure drop, cost-effective design.
#6 deft clay
deft clay
  • 19 posts
Posted 05 November 2025 - 08:53 AM
Is this an AI response?
When I am starting a new S&T exchanger in HTRI, I use 12:1 as a starting ratio to get the design going. That is, 1 foot of length for 1 inch of diameter.
A few points:
  • The easiest and cheapest way to add surface area is to increase the length. There is a limit to that of course.
  • Higher shell lengths tend to increase undesirable bypass.
  • Extremely small shell diameters (under 8") tend to have high bypass% built-in because the tolerances don't scale down.
#7 breizh
  • 6,975 posts
Posted 06 November 2025 - 01:43 AM
Even this is an old thread, I share with you a document issued by Art Montemayor based on works from Dale Gulley.
Note: Every chemical engineer should have a copy of: Process heat transfer by D.Q Kern. 1rst edition.
Additional documents added.
