1. What should be the L/D ratio assumption in Heat Exchanger Design/Rating in HTRI for below systems ?
a. Liquid-Liquid
b. Gas-Liquid
c. Gas-Gas
2. How to reduce the overdesign in HTRI?
Posted 05 November 2025 - 05:54 AM
Posted 05 November 2025 - 08:53 AM
In thermal design, the L/D ratio (Tube Length ÷ Shell ID) isn’t just a number—it’s the sweet spot between performance, cost, and practicality.
???? Too Low (L/D < 3): Oversized shell, poor heat transfer efficiency, higher material cost.
???? Too High (L/D > 12–15): Vibration risks, high pressure drop, fabrication & transport difficulties.
???? Optimum (L/D ~ 6–10): Balanced heat transfer, manageable pressure drop, cost-effective design.
Is this an AI response?
When I am starting a new S&T exchanger in HTRI, I use 12:1 as a starting ratio to get the design going. That is, 1 foot of length for 1 inch of diameter.
A few points:
Posted 06 November 2025 - 01:43 AM
Even this is an old thread, I share with you a document issued by Art Montemayor based on works from Dale Gulley.
Note: Every chemical engineer should have a copy of: Process heat transfer by D.Q Kern. 1rst edition.
Additional documents added.
Selection Of Heat Exchanger For Heating LiquidStarted by Guest_fahctory_* , 24 Feb 2026 |
Kettle-Type Heat ExchangerStarted by Guest_Kentucky08_* , 19 Feb 2026 |
Lng ExchangerStarted by Guest_guoyinyanliner_* , 10 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
