Hi
I'm beginner in HTRI and I want to simulate a Fan-coil heat transfer using Xace (Economizer). the outside fluid (hot fluid) is moist air (27C dry bulb temperature and 19C wet bulb temperature) and tube side fluid (cold fluid) is 7C water. but I can't find any data about latent heat which is important in this systems, when I simulate this case,.
Is HTRI calculated the latent heat? and how?
Is HTRI can calculate local condensation (due to lower surface temperature than dew point) on coil surface?
