Thermal Expansion Psv Leakage
10 replies to this topic
#1 phoenixmoca
phoenixmoca
  • 19 posts
Posted 11 November 2021 - 06:20 PM
There is potential for one ammonia pipe to take a thermal expansion scenario. The psv is employed to protect against the scenario. But it is known that psv has allowable leakage. So my question is whether a rupture disk is needed at the inlet of psv to avoid the ammonia leakage.
Thank you for your comments in advance.
#2 latexman
  • 1,874 posts
Posted 11 November 2021 - 09:42 PM
Where does the PSV discharge to? Can you discharge into another ammonia pipe or the ammonia tank?
#3 phoenixmoca
phoenixmoca
  • 19 posts
Posted 12 November 2021 - 06:58 PM
Hi latexman
The discharge is to flare system.
#4 latexman
  • 1,874 posts
Posted 12 November 2021 - 07:21 PM   Best Answer
If leakage is a concern, I recommend a soft seat (o-ring) PSV. Having to break into the lines to change RDs after every event is just not practical for a TRV.
#5 phoenixmoca
phoenixmoca
  • 19 posts
Posted 12 November 2021 - 09:30 PM
Thank you ,latexman.
#6 fallah
  • 5,026 posts
Posted 12 November 2021 - 11:30 PM
Please specify the TSV set pressure and relevant line operating pressure. It might the leakage is due to small difference between such two pressures.
#7 phoenixmoca
phoenixmoca
  • 19 posts
Posted 15 November 2021 - 12:25 AM
Thank you, fallah. Maybe it is the related point.
#8 latexman
  • 1,874 posts
Posted 15 November 2021 - 06:59 AM
Is TRV set pressure as high as Code allows?  Look at your pipe spec. and adjust set pressure = MAWP.
For metal-to-metal seat, PSV will start leaking at about 90% of set pressure.
For soft seat, PSV will start leaking at about 95% of set pressure.
For PSV that will start leaking at about 98% of set pressure, look at pilot operated PSV..
#9 phoenixmoca
phoenixmoca
  • 19 posts
Posted 15 November 2021 - 07:56 PM
TRV set pressure is the same as protected piping design pressure. Maybe it is preferable to use soft seat against the leak.
#10 fallah
  • 5,026 posts
Posted 15 November 2021 - 11:47 PM
If there is no concern about high temperature to make damage on soft seat, you can use...
#11 phoenixmoca
phoenixmoca
  • 19 posts
Posted 16 November 2021 - 11:45 PM
Yes,latexman. It should evaluate the temperature impact on the soft seat performance.thank you.
