Teg Dehydration Unit Change Operation
dehydration
#1 AriefRahmanHakim
AriefRahmanHakim
  • 7 posts
Posted 13 December 2021 - 06:39 PM
Dear Expert,
If the TEG dehydration unit operated with lower pressure, what things to be attention ?
example the pressure previous 850 psig, and will operate in 621 psig. what happened ?
#2 lnbsak
lnbsak
  • 53 posts
Posted 16 December 2021 - 04:11 PM
Check GPSA engineering handbook have a rough estimation. Generally find if it is PSA and TSA( I forgot to be frank. So if PSA what would be the general answer?
Edited by lnbsak, 16 December 2021 - 04:18 PM.
#3 AriefRahmanHakim
AriefRahmanHakim
  • 7 posts
Posted 21 December 2021 - 10:12 AM
We use TEG Dehydration Unit, not PSA and TSA. what happened with setting my TEG ?
#4 Pilesar
  • 1,631 posts
Posted 21 December 2021 - 03:36 PM
The question may not be clear to me, but lowering the pressure of a flowing gas will cause the actual gas volume rate to increase. The higher gas volume flow will have higher pressure drop and will also reduce any excess column capacity.
