Hcl Acid Piping For Edi Regeneration
#1 J_Leo
J_Leo
  • 262 posts
Posted 09 January 2022 - 06:19 PM
Currently for EDI unit regeneration, HCL acid from a vendor drum is transferred outside of the building to the CIP (clean in place) tank which is located inside a building though a temporary hose. Otherwise, the acid fume is too strong if transferred inside the building.
Is it a good idea to install permanent piping inside the building? Generally for Demin plants, is the HCL acid piping installed permanently inside a building and connected to the CIP tank? Will it reduce hazards overall?
Thank you in advance for any information.
Leo
  • 6,967 posts
Posted 09 January 2022 - 10:56 PM
Not sure I understood the query but I will do a tentative :
To me fume of HCL should be collected and treated ( Scrubber) , check the regulation in your area . It not treated soon I will be a mess in the workshop , corrosion and risk of chemical burns due to condensation of the vapor.
Flexible hoses should be a temporary solution , whenever possible install hard pipe .
Note :CIP tank should be installed in a bund.
https://www.oxy.com/...g_HCl_tanks.pdf
My 2 cents
#3 J_Leo
J_Leo
  • 262 posts
Posted 10 January 2022 - 02:32 PM
Hi Breizh,
Thank you for the information. The scrubber will be installed on the tank to absorb the fume. We are considering adding the permanent piping.
Leo
