Conversion Of Uom
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 15 January 2022 - 05:58 AM
Dear Sir,
How to convert Nm3/hr to MTPH for Compressor Feed Gas Flow . Please help me .
  • 7,070 posts
Posted 15 January 2022 - 06:28 AM
a) You need to know the composition of your steam to calculate the molecular weight of the gas >>> M w  (g/mol)
B) Nm3/h means volumetric flow rate at (0 C and 1 bar ) i.e 1 mole =22.4 liter   >>> Moles/hours
>>>> Mole/h * MW= gr/h /1e06 = MTPH (metric ton per hour)
Hope this is helping you
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 17 January 2022 - 12:23 AM
Dear Sir,
I know conversion from Kmol to kg for feed flow. and also molecular weight contribution to this . But i wanted to know how NTP conditions will affect final calculation here.
Best Regards,
Chetan Chavan
#4 breizh
  • 7,070 posts
Posted 17 January 2022 - 01:03 AM
Thanks to explain better what is your requirement?
Normal means specific condition (0 C and 1 atm) , if you change the condition the consequence will be a change in molar volume (perfect law gas  V =R*T/P)  .
Note : You may use this calculator to support your work
Centrifugal Compressor Performance Calculator (elliott-turbo.com)
