Heating Water To 650Oc
31 replies to this topic
#26 Pilesar
  • 1,695 posts
Posted 25 January 2022 - 09:15 AM   Best Answer
Okay. I can accept that as a premise that you have a reactor that defies the laws of thermodynamics since I have read science fiction novels. To your immediate question of 'how do i get low pressure steam to 650 C?' then the answer is to use a fired heater. The combustion products from the fired furnace will supply the temperature you need to heat the steam. The next questions would be along the lines of 'what materials of construction should I use to transfer heat and contain the low pressure, high temperature steam?' and 'how do I keep the steam from cooling off from 650 C before it enters the reactor?' I haven't read enough science fiction to know those answers.
#27 JArchy123
JArchy123
  • 30 posts
Posted 25 January 2022 - 04:25 PM
Ask my lecturer that question, he helped me to design it.
#28 Pilesar
  • 1,695 posts
Posted 25 January 2022 - 06:29 PM
Well, I don't know your lecturer. I hope my answer was helpful. The details of a real engineering process can require design changes as iteration. In your case, you can probably get away with some hand waving and documenting your assumptions. Would you mind revealing the part of the world where you are getting your education?
#29 JArchy123
JArchy123
  • 30 posts
Posted 25 January 2022 - 06:37 PM
Belfast, Northern Ireland
#30 JArchy123
JArchy123
  • 30 posts
Posted 25 January 2022 - 06:38 PM
The lecturer is meant to have reviewed our section on heat and mass balance and give us feedback but that didn't happen so basically I had to continue with the data given
Edited by JArchy123, 25 January 2022 - 06:39 PM.
#31 JArchy123
JArchy123
  • 30 posts
Posted 25 January 2022 - 07:30 PM
Again, thanks for the help everyone
Kind Regards,
Joel
#32 breizh
  • 7,061 posts
Posted 26 January 2022 - 01:47 AM
Did you try the search engine in this forum ? Pingpong  supported a lot of students on this topic over the years
take a look
