Hi All,
I have understood the requirement of RO in the drain line from the below post.
https://www.cheresou...n-drain-system/
but to clarify is there an concern if the RO is placed in the upstream of the DBB.
Sam
Posted 08 March 2022 - 09:34 PM
Hi All,
Sam
Posted 09 March 2022 - 03:40 AM
Hi Sam,
If there is no phase change across the RO due to draining action; appears no specific concern to be expected for RO placing at upstream...
If there is phase change (liquid to vapor/two phase); putting the RO at downstream is highly preferred...
![]() Restriction Orifice And Correct Location Of Class BreakStarted by Guest_F.Sh_* , 06 Aug 2025 |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Restricted Orifice (Ro) After The Reciprocating Compressor? Why?Started by Guest_VolereePotere_* , 24 May 2023 |
