My basic understanding that we need to install vortex breaker in the liquid outlet lines for the vessels that serves pumps as a protraction to the pump from getting gas into the liquid stream. Is this assumption right or there are other considerations.
Any advice.
Thanks,
Abdullah
Vortex Breaker
Started by Abdullah, Nov 07 2006 04:00 PM
Posted 07 November 2006 - 04:00 PM
Posted 07 November 2006 - 07:31 PM
That's basically the answer. At some low level point, the liquid will start to swirl in a circular motion. You can see this effect in your sink as water goes down the drain. This will have the tendency to suck any vapor from the vapor space into the liquid stream thus causing pumping problems. The vortex breaker will stop this swirl effect.
![]() Concerns Regarding Vortex FlowmeterStarted by Guest_JKM_* , 11 Jul 2024 |
![]() Discharge Syphon - Vacuum Breaker VentStarted by Guest_lsoaresfernandes_* , 22 Feb 2022 |
Vacuum BreakerStarted by Guest_CSNK_* , 06 Nov 2019 |
Vortex And DrainingStarted by Guest_raj shekhar_* , 06 Feb 2019 |
Foam Breaker SelectionStarted by Guest_Nico_93_* , 07 May 2015 |
