Hi, I have a simulation file with some adjust, recycle and set functions going on. The convergance criteria is somewhat strict, but it converges quite fast as long as the input variables is not changed too much.
I have quite a lot of design cases to look into, but the discrepancy between cases is not very large so it converges quite quickly and well within max iterations for the different functions.
The problem I get when I have set up the discrete type, design study cases and have put all the states in, it doesn't move from state 1 to state 2. All unit ops have converged and I cant find no errors.
So everything seems to go fine when I press run, but it doesn't move to the next case even though the case has converged.
Does anyone have any tips with regards to what conditions needs to be met before it jumps to next state?
Thanks for any help!
Best regards,
Daniel
