Is there any way to achieve 2bar with blowers (e.g. in series)? or only compressor is the solution.
My gas is at 1000oC.
Posted 25 April 2022 - 07:48 AM
Posted 26 April 2022 - 11:29 PM
In general, a blower has a typical pressure rise from 1.11 to 1.2. Then considering the suction pressure you can evaluate if a blower can be selected to reach the discharge pressure of 2 bara.
Edited by fallah, 26 April 2022 - 11:58 PM.
Posted 27 April 2022 - 06:19 AM
Are you sure about the temperature ? weird to me
What is the unit of pressure ? Absolute or Gauge .
What about the flowrate ?
What about the quality of the gas ? clean or dirty ?
https://hrblowers.co...ASAAEgLxVPD_BwE
note : Compression selection chart attached .
Posted 27 April 2022 - 11:18 AM
By "blower", do you mean a centrifugal fan? I'm pretty sure that's what you mean.
In some countries and industries, "blower" can also mean a rotary lobe compressor, like Roots Blowers.
Posted 27 April 2022 - 09:52 PM
A guide to support young engineers , should not be taken " stricto sensus "
Posted 01 June 2022 - 08:35 AM
Yes i refer to centrifugal fan.
2bara final pressure.
This is a flue gas
Edited by kangas, 01 June 2022 - 08:36 AM.
Posted 03 June 2022 - 10:52 PM
It looks like this fuel gas is coming from high temperature reactor. I think the fuel gas should be cooled before it reused. After cooling, there a lots of way to increase the pressure. Otherwise, such high temperature would be a great challenge for equipment.
Variable Frequency Drives Control Scheme For Rotary BlowersStarted by Guest_Jome128_* , 30 Mar 2013 |
Soot Blowers For Circulating Fluidized Bed BoilersStarted by Guest_Asim Qaiser_* , 03 Apr 2012 |
Flat Bottom BlowersStarted by Guest_Shrikant Koli_* , 26 Mar 2012 |
Soot BlowersStarted by Guest_Narnia_* , 19 Dec 2011 |
Performance Check Of BlowersStarted by Guest_asmsyn_* , 03 Aug 2011 |
