I am new to Hysys (day 3) and have a question for the group.
The pipeline group asked to verify quantities associated with launching/receiving a pipeline pig as well as other maintenance activities at a remote site (pump, meter etc). I thought with HYSYS a generic template could be created and used at all remote sites with adjustments to the components.
I arranged my model with a PCV at the launcher/receiver to show the 1400 dp. This was the only way I could come up with showing part of the system with zero pressure.
Piped it to the KO Drum with 2 outlets.
For The liquid outlet I added another PCV with 0% opening to block flow. The drum will be evacuated with a truck and is not tied to a closed drain system.
I have not yet figured out where to get a closed block valve.
Ran the simulation for the estimated time duration figured on separate excel sheet.
It was able to produce a volume in the drum pretty close to what we figured by hand.
Question is what is the proper way to do this in hysys?
I tried the Blowdown and depressure utilities. I am sure with more time this is the appropriate method.
The question I have with it is the "vessel" it brings up and how it fits into the system.
Product is Y-Grade
