Hi all,
For cooling tower chemical dosing, which flow rate i should take as a basis for dosing rate calculation?
Any previous experience in cooling tower dosing rate calculation will be helpful to know more.
Posted 23 May 2022 - 08:55 AM
Hi all,
Posted 23 May 2022 - 07:11 PM
Nobody can answer this question without information about the quality of the water fed to your system and type of treatment allowed in your location .
Normally we ask vendors of chemicals to come at site to perform a survey and to suggest a plan for treatment including chemical dosage , cost for a given period and technical assistance through regular visits where analysis are performed .
My view
Posted 24 May 2022 - 12:55 AM
Does not make sense to me !
Use the service of a professional familiar with cooling water treatment and follow his/her recommendations . You should have information about make up water , blowdown and evaporation . Normally the quantity of chemicals injected is proportional to make up water or blowdown to compensate the loss of chemical .
It seems you have a Ph adjustment , a Ph probe should help you to monitor in line the cooling water and prevent deposition of salts.
You should have info about other chemicals to add to prevent corrosion and foulant , probably biocide too to prevent legionella .
As I said a reputable chemical company versed on cooling water should help you to manage your system.
Let you study this document to support your work :
https://www.suezwate...g-water-systems
Best of luck
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
I Have A Question From Himmelblau's Introduction To Chemical EnginStarted by Guest_Hindxxx//_* , 27 Jan 2026 |
Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
Distillation Tower Top And Bottom Temperature And PressureStarted by Guest_student55_* , 27 Mar 2016 |
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
