Rated Flow Of Pump
rated flow
#1 R_Gowtham
R_Gowtham
  • 15 posts
Posted 21 June 2022 - 12:30 AM
Hi all,
What is the significance of rated flow of pump?
How to calculate the rated flow of pump?
what action should i take my rated flow is higher than the vendor provided rated flow?
  • 6,936 posts
Posted 21 June 2022 - 03:58 AM
rated flow= design flow = normal flow + some margin
for the other questions it probably has to do with what you supplied to the vendor (specification sheet) ,
To get a better answer supply your specification sheet and pump curve with operating point ( TDH vs Qv)  from vendor.
#3 R_Gowtham
R_Gowtham
  • 15 posts
Posted 21 June 2022 - 05:18 AM
Norma flow rate - 0.05GPM
Rated flow - 1 GPM
differential pressure required - 50psi
#4 Pilesar
  • 1,635 posts
Posted 21 June 2022 - 07:12 AM
If your service requires flow conditions that the pump cannot satisfy, then the pump is not suitable. The pump curve you attached indicates the maximum flow of the pump is less than 0.01 gpm.
#5 R_Gowtham
R_Gowtham
  • 15 posts
Posted 21 June 2022 - 11:54 PM
Rated flow - 1 GPM
Sorry for the error "GPM". actually its GPH
Please refer the below parameters:
Normal flow rate is 0.05 GPH
Rated flow is 1 GPH
Differential pressure - 50psi
#6 breizh
  • 6,936 posts
Posted 22 June 2022 - 04:59 AM
Can you share a process description for better understanding ?  more info are also needed about the pump technology and vendors .
BTW one vendor is never sufficient to make a choice !
#7 Bobby Strain
Posted 22 June 2022 - 12:39 PM
This pump only delivers ~0.5 gph @ 50 psi. So, 1 gph is NOT the rated flow.
