Not yet we are still facing the same problem. we did everything as suggested here in this group but still problem is there.
Posted 26 July 2022 - 03:23 AM
Posted 26 July 2022 - 04:50 AM
Usually TEG circulation pump is reciprocating. I don't see any heat recovery/temperature drop of lean TEG before entering to TEG pump suction. (TEG pressure/Temp as your material balace: 6.5 psig & 359 Deg F(181 Deg C). Normally there is a Plate Heat Exchanger (PHE) before TEG entering to pump suction and a HH Temperature trip of TEG Circulation pump to avoid TEG degradiation (usually TEG bath temperature is maintain at 204 Deg C and not to exceed 210 Dg C). In your attachment there is no such PHE or Temp HH to trip of pump. We have two dehydration unit where TEG circulation pump operating temperature is 80 Deg C and a HH temperature is 130 DegC. I surprised to see your TEG Circulation pump temp is 181C (as lean TEG temp). As you mentioned plant were running 10 years before smooth and now creating problem. Is there any change/modification of the plant? Compare the data before and after 10 years. I am afraid TEG reach to vapor state whenevr it enter into pump suction and a result of cavitation.
As i metioned earlier there are four similar Gas Dehydration Trains with same capacity and similiar deisgn and all have the same problem. Is it possible that in all trains TEG reached upto temperatrue where it vaporize even through all units are running as per normal operating conditions and no changes observed. ![]()
Working With Old/paper Pump Performance Curves — How Do You Convert AnStarted by Guest_arundhamodharan_* , 23 Aug 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
